Bavarian Railways - My N scale Collection
Hier können Bilder von Modellbahnen und Modellautos eingestellt und besprochen werden.
FloS
Beitrag von FloS » Samstag 10. November 2007, 18:07
Hello everybody!
I'm not a modeller, yet, because I have no space or time for layout building... for the moment i'm just a models collector.
Here, I wanna show you: K.BAY.STS.B my N Scale Collection.
ARNOLD 2276 - Gt 2x4/4
Specifications:
Axle configuration: D'D' h4vt
Wheel diameter: 1216 mm
Overall length: 17500 mm
Wheelbase: 12200 mm
High pressure cylinder diameter: 2 x 520 mm
Low pressure cylinder diameter: 2 x 800 mm
Piston stroke: 640 mm
Grating area: 4.25 m2
Heating surface: 14.75 m2
Superheating surface: 55.3 m2 for 96 001 - 015
57.7 m2 for 96 016 - 025
Top speed: 50 km/h
Fully laden weight: 123.2 tons 96-001 - 015,
127.6 tons 96-016 - 025
Water Supply: 11 m3
_________________________________________
Arnold built this model in 1982.
Manufacture period: 1982-1991
Overall length: 110,60 mm
Details and other pictures here:
http://kbaystsb.blogspot.com/2007/11/ar ... 44_28.html
FLEISCHMANN 7819 - GtL 4/4
Specifications:
Axle configuration: D h2t
Wheel diameter: 1006 mm
Overall length: 9250 mm
Wheelbase: 3900 mm
Cylinder diameter: 460 mm
Piston stroke: 508 mm
Grating area: 1.34 m2
Heating surface: 5.85 m2
Superheating surface: 18.36 m2
Top speed: 40 km/h
Fully laden weight: 43 tons
Water Supply: 5 m3
Fleischmann 7819 is a part of Fleischmann 7889, a Limited Edition Special Set produced in 1992.
http://kbaystsb.blogspot.com/2007/10/fl ... tl-44.html
MINITRIX 11011 Special-Set - R 3/3
Specifications D II - R 3/3 (2473-2490):
Axle configuration: Cn2t
Overall length: 9410 mm
Wheelbase: 3700 mm
Cylinder diameter: 420 mm
Piston stroke: 610 mm
Grating area: 1.61 m2
Heating surface: 6.40 m2
Top speed: 45 km/h
Fully laden weight: 44.8 tons
Water Supply: 5 m3
MINITRIX 11011 Special-Set was released in 1991 and comprises:
Bavarian Tank Locomotive Class R 3/3 and 5 freight cars.
http://kbaystsb.blogspot.com/2007/10/mi ... l-set.html
MINITRIX 11013 Exclusiv-Set - D II
Specifications D II:
Wheelbase: 3700 mm
Top speed: 45 km/h
Water Supply: 5 m3
In 1900, from the first lot of Maffei's locomotives, five arrived in Romania (factory number 2130, 2133, 2135, 2140, 2141).
Therefore, factory numbers and train numbers of this Maffei-delivery got somehow mixed up.
BTW, i'm from Romania :)
MINITRIX 11013 Exclusiv-Set was released in 1989/1990 and comprises:
Bavarian Tank Locomotive Class D II and 4 cars (C+BC+PwPostL+Beer car)
http://kbaystsb.blogspot.com/2007/10/mi ... -d-ii.html
MINITRIX 11015 Special-Set - PtL 2/2
Specifications:
Axle configuration: Bh2t
Overall length: 6980 mm (4507-4535) 6780 mm (4536-4548)
Wheelbase: 3200 mm (4507-4535) 2700 mm (4536-4548)
cylinder diameter: 320 mm
Piston stroke: 400 mm
Grating area: 0.6 m2
Heating surface: 3.05 m2
Superheating surface: 8.1 m2
Top speed: 50 km/h
Fully laden weight: 22.7 tons (4507-4535) 22.1 tons (4536-4548)
Water Supply: 2 m3
MINITRIX 11015 Special-Set was released in 1989 and comprises:
Minitrix 12017 Bavarian Class PtL 2/2 (Glaskasten / Glass Box) and 3 cars
http://kbaystsb.blogspot.com/2007/10/mi ... tl-22.html
MINITRIX 11021 The Wedding Train, released in 1997.
A Special Event, the "Marriage" between Märklin and TRIX, required a Special Set for celebration.
___________________________________________
http://kbaystsb.blogspot.com/2007/10/mi ... train.html
MINITRIX 11029 Exclusiv-Set - G 3/4 H
Locomotive Specifications:
Axle configuration: 1 C h2
Drive wheel diameter: 1350 mm
Ahead wheel diameter: 950 mm
Cylinder diameter: 520 mm
Piston stroke: 630 mm
Grating area: 2.65 m2
Heating surface: 10.12 m2 (7001-7065), 10.06 m2 (7066-7225)
Superheating surface: 37.7 m2
Top speed: 65 km/h
Fully laden weight: 54.5 tons (7001-7065),
55.5 tons (7066-7165), 56.2 tons (7165-7225)
Tender Specifications:
Coal Supply: 6 m3
Water Supply: 18 m3
MINITRIX 11029 Exclusiv-Set comprises:
Minitrix 12903
Locomotive G 3/4 H and other 4 cars
http://kbaystsb.blogspot.com/2007/10/mi ... -34-h.html
MINITRIX 11604 Limited Edition-Set
Specifications:
Axle configuration: B’B n4v
Overall length: 10010 mm
Wheelbase: 5200 mm
High pressure cylinder diameter: 310 mm
Low pressure cylinder diameter: 490 mm
Piston stroke: 530 mm
Grating area: 1.4 m2
Heating surface: 5.7 m2
Top speed: 45 km/h
Fully laden weight: 41.6 tons (2501-2525),
41.8 tons (2526-2531)
Water Supply: 4.3 m3
Coal supply: 1.5 tons
Minitrix 11604 set has been produced in a one-time series only in 2004 and comprises:
Bavarian Tank Locomotive Class BB II, 0-4-4-0T Mallet design + 2 passenger cars + 1 mail/baggage car
http://kbaystsb.blogspot.com/2007/10/mi ... n-set.html
MINITRIX 12035 - S 2/5
Axle configuration: 2‘B1 n4v
Drive Wheel diameter: 2000 mm
Front wheel diameter: 950 mm
Back wheel diameter: 1206 mm
Overall length: 19228 mm
High pressure cylinder diameter: 340 mm
Low pressure cylinder diameter: 570 mm
Grating area: 3.27 m2
Heating surface: 14.5 m2
Top speed: 110 km/h
Fully laden weight: 32 tons
Bavarian Express passenger locomotive Class S 2/5
Built by Maffei in 1904.
http://kbaystsb.blogspot.com/2007/10/mi ... -s-25.html
MINITRIX 12226 - S 3/6
Specifications (road number 3601-3623 / 3642-3649):
Axle configuration: 2C1 h4v
Drive Wheel diameter: 1870 mm
Overall length: 21221 mm
Grating area: 4.5 m2
Heating surface: 201.7 m2
Top speed: 120 km/h
Service weight: 88.3 tons / 89.7 tons
Water Supply: 26.2 m3
Coal supply: 7.5 tons
Royal Bavarian State Railroad class S 3/6,
4-6-2 design.
Built starting in 1908.
Use: Heavy express passenger trains.
road number 3644
Overall length: 134 mm
http://kbaystsb.blogspot.com/2007/11/mi ... -s-36.html
MINITRIX 15135 - Gas Tank Cars Set
The original of this gas tank cars have been already built around 1893.
Filigrane reproduction of the flanges and armatures.
Close coupling
Road numbers 500051, 500055, 500059
Set overall length: 151 mm
Released in: 2002-2003
http://kbaystsb.blogspot.com/2007/11/mi ... s-set.html
MINITRIX 13804 Beer Car
Freiherrlich von Tuchersche Beer Car Nürnberg
Used on the Royal Bavarian State Railways.
Built in 1891, provincial railroad car type.
Gray spoked wheels
Close coupler mechanism.
Road number: 85425 Nürnberg
Overall length: 58 mm.
______________________________________________
http://kbaystsb.blogspot.com/2007/11/mi ... r-car.html
MINITRIX 15039 Beer Cars Set has been produced in a one-time series only in 2002, initiated by MHI (Märklin Händler Initiative) and comprises:
Minitrix 15039 001, 002, 003 K
Beer Cars type G 10 "Hacker Bräu", "Kochel Bräu", "Pschorr Bräu"
Overall length of the set: 167mm
MINITRIX 15038 Beer Car
exclusively produced for "Spielzeugring, MC & VEDES" in 2001
Beer Car type G 10 "Pschorr Bräu"
Close coupling
Road number 80510 München
Overall length: 55mm
MINITRIX 13218 Beer Car
Beer Car type G 10 "Hacker Bräu"
Built in 1914.
Road number 601787 München
Manufacture period: 1986 - 1992
MINITRIX 13801 Beer Car
Beer Car type G 10 "Thomasbräu München"
Built in 1906.
Road number 80646 München
Close coupling
Overall lenght: 55 mm
Manufacture period: 1997 - 1999
MINITRIX 15036 Beer Car
Exclusively produced for "Trix PROFI CLUB" in 2000
Beer Car type G 10 "Joh. Humbser"
Close coupling
Road number 601911 Nürnberg
Overall length: 55 mm
Manufacture period: 2000
MINITRIX 13418 Beer Car
Beer car with a brakeman’s cab "Stadtbrauerei Spalt"
Type G 10mB
Built in 1893.
Close coupling
Road number 85642
Manufacture period: 1993 - 1996
This car is also part of MINITRIX 11013 Exclusiv-Set
MINITRIX 15113 Limited Edition-Set
Minitrix 15113-001 K
Beer Car "Unionsbräu Schülein & Co."
Type G 10 mB
Close coupling
Road number 601784 München
http://kbaystsb.blogspot.com/2007/11/mi ... n-set.html
MINITRIX 15143 Limited Edition-Set
Minitrix 15143-003 K
Beer Car "Brauerei Lorenz Stötter Akt. Ges. Augsburg"
Type G 10 mB
Built in 1893
Close coupling
Road number 601883 Augsburg
MINITRIX 12231 - S 3/5N
Bavarian Express passenger locomotive Class S 3/5N,
4-6-0 design.
Built by Maffei in 1903.
Road number 3306
Overall length: 123 mm
Manufacture period: since 2002
http://kbaystsb.blogspot.com/2007/11/mi ... s-35n.html
MINITRIX 15021 Limited Edition Car
Released in 1999.
Flat Car with a Christmas Tree
Road number 241299
http://kbaystsb.blogspot.com/2007/12/mi ... n-car.html
I wish you ALL:
Merry Christmas and a Happy New Year
Froue Weihnåcht'n, und a guad's nei's Joah
ARNOLD 2530 - S 3/6
Royal Bavarian State Railroad class S 3/6, 4-6-2 design.
Road number 3610
Overall length: 159 mm
Manufacture period: 1977 - 1986
Leader house and boiler made of metal, without golden boiler rings
http://kbaystsb.blogspot.com/2007/11/ar ... -s-36.html
MINITRIX 12834
0-4-4-0T Mallet design.
Built in 1901, by Maffei.
Road number 2525
Manufacture period: 1990-1996
Overall length: 64 mm
http://kbaystsb.blogspot.com/2007/11/mi ... bb-ii.html
for comments ...english please
Best regards!
Florin Sev
Zuletzt geändert von FloS am Dienstag 8. Januar 2008, 12:42, insgesamt 1-mal geändert.
silberner dreier bmw
Beitrag von silberner dreier bmw » Sonntag 9. Dezember 2007, 20:41
It's a very nice collection!! Keep collecting... :D :D
Gruß, Max
Münchner in England.
Modellbahnen aus EU, GB & NA.
mInsider
FloS
Beitrag von FloS » Dienstag 11. Dezember 2007, 20:28
Thank you for apreciation silberner dreier bmw!
MINITRIX 13262
Flat Car with a brakeman’s cab "MAN"
Type SSml
Built in 1901
Close coupling
Road number 67554 Nürnberg
Overall length: 107 mm
Manufacture period: 1992 - 1995
http://kbaystsb.blogspot.com/2007/12/mi ... r-man.html
Best regards!
Florin Sev
Beitrag von silberner dreier bmw » Mittwoch 12. Dezember 2007, 09:10
I see, you keep collecting... :wink: and you continue with another nice model. :D
greetings
silver bmw three...
Gruß, Max
mInsider
FloS
Beitrag von FloS » Donnerstag 13. Dezember 2007, 10:47
MINITRIX 11412 Limited Edition Set
Bavarian Flat Car with a brakeman’s cab
Type SSml
Built in 1901.
Close coupling
Road number 78915
MINITRIX 13406
"Eisenwerk Nürnberg A.G. Tafel & Co."
Type SSml
Built in 1901
Close coupling
Road number 67549 Nürnberg
Manufacture period: 1996 - 1997
http://kbaystsb.blogspot.com/2007/12/mi ... t-car.html
Best regards!
Florin Sev
Qrt
Beitrag von Qrt » Samstag 5. Januar 2008, 01:57
It shall be interresting to see if Fleischmann will produce green varieties of their new DR Fahrzeuge of Bavarian origin.
Mit freundlichen Grüßen - Qrt
FloS
Beitrag von FloS » Sonntag 6. Januar 2008, 13:19
Hello everybody!
HAPPY NEW YEAR!
MINITRIX 12603
Bavarian Locomotive Class G 4/5 H
Built by Maffei in 1915.
Use: Medium and heavy freight train service
Road number 5502
Manufacture period: 1995 - 1998
Overall length: 117 mm
http://kbaystsb.blogspot.com/2007/12/mi ... -45-h.html
MINITRIX 12607 Limited Edition
was released in 1998 only.
Built by Maffei in 1916.
Road number 5528
MINITRIX 15005 Limited Edition-Set
was released in 1998 and comprises 5 bavarian cars:
High side gondola with a brakeman’s cab
Boxcar with a brakeman’s cab
Medium height gondola with a brakeman’s cab
Low side gondola with a brakeman’s cab
Boxcar
Best regards!
Florin Sev
